Here's a good brain teaser for you Dodge guys. We went to replace the timing chain on my truck last week, Brought #1 on TDC on commpression stroke, took front off the engine and the Timing dots were lined up with the Cam gear dot on top and the crank gear was at the top. Now all the manuals that I have say the dots are to be lined up Bottom of Cam gear and Top of the Crank gear. So buy looking at this the Cam was 180' out of time but the truck was running. We tried to line the dots up buy the books and the truck wouldnt hit a bit. Now after a week of cussing and asking everyone I know, they are all stumped. So today I took it back apart and lined the Cam gear dot at the top and #1 at TDC ON COMMPRESION STROKE, which put the Crank gear dot at the top. Took both valve covers off and made sure that both valves on #1 and #8 were closed. And guess what the truck fired right up. I know the motor has never been apart before so what gives????? The cam must have been made with the key way 180' out from the factory. Or did Dodge make 318's that the marks line up like this????????? I bet the motor guy at the factory had a hell of a time trying to set this motor up. OH AND TO LET EVERYONE KNOW A 318 WILL NOT RUN IF THE CAM IS 180' OUT AND YOU CAN NOT MAKE UP FOR IT IN THE DISTRIBUTOR!!!!!!!!!!! So when you get a new timing set for your truck and you are sure that you brought #1 up on TDC on the commpression stroke and the timing mark to 0' DONT MOVE THE CAM GEAR 180' IF THE DOTS ARE LINED UP WITH THE CAM GEAR DOT ON THE TOP!!!!!!!!!!!
