Hey everyone... I searched the forums but can't find some solid info on how to actually do this. I have 1996 Caravan with a 3.0. The serpintine belt is sqealing bad and it needs to be changed. I am used to the old "loosen the alternator" type of belt change. The car has AC but that belt is not on there because the AC is shot. So that is not in the way.
Can someone give me some help with changing this? I see the two pullies on the pushing against the smooth side of the belt. I assume one of these are tension pullies maybe spring loaded or something. But how to I go about loosening them to get the old belt off? I assume there are no adjustments on the Alternator like the good old days. Since the alternator is facing toward the fire wall.
